I need to know how to install lifters
Old Feb 29, 2004 | 05:38 PM
snakeatinZ's Avatar
Is it hard to do??? I have a high rpm miss and I am hot on the trail of fixing it. I think it is the lifters, so I am going to install comp R. Can anyone track me down a write up? Also need a write up for injectors and racetronics fule pump.
thanks alot,
Steve
Old Feb 29, 2004 | 05:51 PM
97WRAITH's Avatar
It is not that hard to do.Get a Hayes manual it has step by step insructions.good luck
Rob.
Old Feb 29, 2004 | 06:20 PM
Kryckter's Avatar
What made you conclude that the lifter's are causing this High RPM miss. I would check other places first. Alot of work and I have not heard of lifters causing a miss. Main thing would be to check your plugs and wires and make sure they are good! And then maybe check for adequate fuel pressure and so on! Good Luck!
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Mar 5, 2015 07:05 AM
