I need help guys!!!!!!!!!
Here's the deal, I had a bad fuel pump, I changed it the car started right up, drove it for about 50 miles, then car started sputtering and going on like it wasn't getting any fuel. Then after sitting overnight car wouldn't start. Finally got it started, and it sounded awful, I made decesion that it was the fuel filter, because it sounded as if it wasn't getting enough fuel. Changed that now the car won't start and the fuel pump is working. Do you think that it was something to do with the ignition, if so where should I start, coil pack, and ignition mod. or what. Please help me.
Re: I need help guys!!!!!!!!!
If you're sure the pump is functioning correctly (you can hear it prime) then go ahead and take a look at your wires, especially your ignition coil wire. A little more info might help us give you more of a hand as well.
Does anyone else have any suggestions, I am buying a new coil, and ignition module today. The car has 100000+ so, I am going to change, plus the car has set for almost 4 years, just trying to get it back on the road, getting a divorce and time to play alot so I'm going to mod the hell out of this car, just need to get all the other bugs worked out. The coil was changed about six years ago, with xx number of miles can't remember when. Like I said new, fuel pump, new fuel filter, now won't start at all.
carguy0119
Apr 11, 2016 11:11 PM
mspennyhughes
Nov 28, 2014 03:22 PM
