View Poll Results: what cam should i use
compxfi 467
0%
compxfi 468
12.50%
gm 847
87.50%
Voters: 8. You may not vote on this poll
I need help with a cam. don't know what cam to buy.
Old Mar 10, 2007 | 04:06 PM
osolow's Avatar
MY CAR:
6''rod 381 all forged and splayed 4 bolt main.
stock ported 54mm tb
ported stock heads(flow 275 @ 600lift)
ported intake
42lb injectors
hooker shorties
underdrive pulleys
borla cat back (no cat)
t56 with 456 gears out back
I will be spraying 150 to 200 shot and i will shift around 7000rpms
I need help with a cam. I don't know witch 1 to buy. here are my choices.
COMP XFI CAMS
467 specs-230/236 576/570 113lsa
468 specs-242/248 584/579 113lsa
OR the gm 847
Old Mar 10, 2007 | 04:19 PM
Heatmaker's Avatar
Advanced Member
With that motor.... I'd say go custom.... why have a dynamic engine.... with an off the shelf cam.
Old Mar 10, 2007 | 04:29 PM
osolow's Avatar
I don't have time to wait for a custom cam, and i am having trouble trying to get ahold of Bret. So i narrowed it down to these cams. Let me know.
Old Mar 10, 2007 | 04:41 PM
Heatmaker's Avatar
Advanced Member
THere are companies out there that already have custom cams in stock.
you have to search around a bit.
Old Mar 10, 2007 | 09:46 PM
osolow's Avatar
any1 else?
Old Mar 10, 2007 | 09:47 PM
mdacton's Avatar
would def. have a custom one ground
Its not much more, and well worth it
Old Mar 10, 2007 | 11:04 PM
snakeatinZ's Avatar
I say go with the Gm 847. With the heads, M6 tranny and gears you have, it will perform outstanding results. You wont be disappointed. I would like to see a video of your set up on the track when you get it done.
Steve
Old Mar 11, 2007 | 10:35 AM
95Blackhawk's Avatar
What is it you are wanting to do with your car? You have to consider the use.
Old Mar 11, 2007 | 12:57 PM
95ttoplt1's Avatar
I have the 847 and am Very happy, it could use a little more top end pull though. It seems to quit about 63-6400.
Old Mar 11, 2007 | 04:27 PM
Heatmaker's Avatar
Advanced Member
yep, and a custom grind could give him those specs and an unlimited redline.... but he doesn't want to listen.
Old Mar 11, 2007 | 04:38 PM
Z95m6's Avatar
Do you have stock heads? most people with that cam have no problem reving to 6500-7000.
Old Mar 11, 2007 | 05:26 PM
95ttoplt1's Avatar
Yes I have stock heads, for now but a 381 will bring the RPM range down a little as well from what a 350 would do.
oldschool
Feb 9, 2016 09:21 PM
Cam's maro
Jan 30, 2015 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
GigaMp3z
Feb 20, 2003 02:57 PM
