I Need Help Asap!!!!!!!! Thanks
Old Sep 8, 2005 | 08:56 PM
SSConceptz's Avatar
I have a 1996 Camaro with a T-56. Well the problem is I dont know if it's the engine or the transmission so I will post it in both. The clutch feels fine. Well I start the engine up and then release the clutch. When I put it in gear and try to go it wont and I release the clutch and the car will rev and not stall. So in other words It wont move at all, I'm thinking either the clutch fork is engaging but not releasing the pressure plate or something in there is screwed or just fell off. Any suggestions? Thanks
Old Sep 8, 2005 | 09:01 PM
blind527's Avatar
Re: I Need Help Asap!!!!!!!! Thanks
That's possible. But I don't know if manuals have it, I had the same problem but my hydraulic pump in my transmission went out.
Old Sep 8, 2005 | 09:03 PM
SSConceptz's Avatar
So you have an automatic? If so, totally different.
Old Sep 8, 2005 | 09:07 PM
turbo_Z's Avatar
Did you try all the gears?
Old Sep 8, 2005 | 09:45 PM
SSConceptz's Avatar
All gears, goes in gear easy, clutch feels good, try to go and it just revs as if Im in nuetral.
Old Sep 9, 2005 | 11:16 AM
95patriotZ's Avatar
you allready posted this same problem in another thread. You should just stick with one thread otherwise its too hard to follow your problem. In your other thread you said you just got it back from somewhere. Where did you get it back from and what did you get done to it? This sounds kinda weird but sounds like the drive shaft isn't connected! That, or the clutch isn't engageing AT ALL. If it was engaging a little you would either feel it or smell it sliping. Need more info on the history of your car i guess.
Old Sep 9, 2005 | 07:05 PM
SSConceptz's Avatar
I posted the same exact thing but I lost the thread but I started this one but now I'll keep to this one. The problem I dont think is the drive shaft, I wonder if it's still there. It is connected but you can hear some noise in the bellhousing.
Old Sep 9, 2005 | 08:57 PM
SSConceptz's Avatar
Driveshaft is there.
Old Sep 10, 2005 | 06:03 AM
slopokrodrigez's Avatar
You could do this quick experiment. Park it on a hill and put it in gear. With the parking brake OFF it should not roll. If it rolls, the clutch is not engaging the flywheel. But you can't drive the thing so try this.
Put it in gear with the P brake off. Raise one rear wheel off the ground, leave the other touching the ground. If you can now spin the wheel that is off the ground by hand, the clutch is not engaged to the flywheel.
Since the clutch is hydraulic, you would never know if the pressure plate is bad since the feeling at the pedal is always the same. I would put money on either the clutch disc is hung up on a corroded tranny input shaft or the clutch fork is bent or broken.
Was the car always in Dallas since new? I have a reason for asking.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
