i need a few part numbers.
1. coolant temp sensor
2. oil pressure/fuel cutoff switch
is there a place online where i cane look up these part numbers? they are kinda real specific parts, that wouldnt turn up in any ole parts search.
for a 94 LT1
thanks
Brandon
for a 94 LT1
thanks
Brandon
If you do a search for "download camaro" you should find a post where you can download a parts book for the 4th gen camaro.
If you have a firebird, most of the parts are indentical. But someone also posted a link to download the firebird version. Just try another search for "download firebird" and you should find it.
i searched both, but cant find anything. found a post where the guy wanted to download a chiltons but there isnt such a thing.
i have the firebird motor, no car though. these parts were just broken while taken some wiring off, while doing some work on it.
Brandon
Brandon
I dont have the p/n's but there are 2 coolant sensors.. one in the drivers side head, for the temp guage, and one in the water pump housing, for the PCM..
Also, the oil sending unit is for the oil pressure guage.. it has nothing to do with 'shutting fuel off'..
hope this helps..
hope this helps..
hope this helps..
hope this helps..
and as for the 2 temp sensors...i think its the one in the water pump that just broke off.
Brandon
I assume you mean that 'sensor fuel pump sw & oil pressure guage' [rear of block behind intake manifold] p/n 10201491
If it's down by the oil filter it's p/n 24575127
I never heard of a 'low oil pressure/fuel shutdown' feature on LT1's.. but it is listed as such... guess I learned something today!
The PCM[water pump housing] sensor is p/n 12146312
Above for 94 LT1's..
and thanks!
Brandon
Brandon
Brandon
I think there is something wrong with the search engine. There have been lots of things I know are there that are not showing up in searches lately.
Originally posted by LWillmann
Do you have the newest version of Adobe Acrobat Reader?
I don't have my laptop with me or I would go ahead and look the numbers up for you...
I think you need Adobe 5.0 or later....
yeah im pretty sure i got a newer version...like 9.0 or something..all my other files open in it.
i just wanted it for future reference, in case this kinda thing happens again
Brandon
Brandon
