i need a few part numbers.
Old Jun 12, 2003 | 03:09 PM
Lightning-Killer's Avatar
1. coolant temp sensor
2. oil pressure/fuel cutoff switch
is there a place online where i cane look up these part numbers? they are kinda real specific parts, that wouldnt turn up in any ole parts search.
for a 94 LT1
thanks
Brandon
Old Jun 12, 2003 | 03:19 PM
LWillmann's Avatar
If you do a search for "download camaro" you should find a post where you can download a parts book for the 4th gen camaro.
If you have a firebird, most of the parts are indentical. But someone also posted a link to download the firebird version. Just try another search for "download firebird" and you should find it.
Old Jun 12, 2003 | 03:37 PM
i searched both, but cant find anything. found a post where the guy wanted to download a chiltons but there isnt such a thing.
i have the firebird motor, no car though. these parts were just broken while taken some wiring off, while doing some work on it.
Brandon
Old Jun 12, 2003 | 04:58 PM
Mtrhds94Z's Avatar
I dont have the p/n's but there are 2 coolant sensors.. one in the drivers side head, for the temp guage, and one in the water pump housing, for the PCM..
Also, the oil sending unit is for the oil pressure guage.. it has nothing to do with 'shutting fuel off'..
hope this helps..
Old Jun 12, 2003 | 05:14 PM
hope this helps..
so what happens if theres no oil pressure....do you still get fuel? thats the best way my buddy described it. not a sending unit(could be, probably another name for it) but a sensor that cuts fuel if you get no oil pressure.
and as for the 2 temp sensors...i think its the one in the water pump that just broke off.
Brandon
Old Jun 12, 2003 | 08:20 PM
Mtrhds94Z's Avatar
I assume you mean that 'sensor fuel pump sw & oil pressure guage' [rear of block behind intake manifold] p/n 10201491
If it's down by the oil filter it's p/n 24575127
I never heard of a 'low oil pressure/fuel shutdown' feature on LT1's.. but it is listed as such... guess I learned something today!
The PCM[water pump housing] sensor is p/n 12146312
Above for 94 LT1's..
Old Jun 12, 2003 | 08:55 PM
just in case what was the other part number for the other coolant temp sensor?
and thanks!
Brandon
Old Jun 12, 2003 | 09:14 PM
Mtrhds94Z's Avatar
and thanks!
Brandon
25037332
Old Jun 12, 2003 | 09:59 PM
Brandon
http://web.camaross.com/forums/showt...hreadid=121162
I think there is something wrong with the search engine. There have been lots of things I know are there that are not showing up in searches lately.
Old Jun 13, 2003 | 09:41 AM
Mtrhds94Z's Avatar
Yes, too bad we don't have an actual 'archive' of all the good info here..
Shame it all goes away in a few short months[only destined to be repeated and repeated..]
Old Jun 13, 2003 | 12:32 PM
Angry
after a 9 hour, 46 minute download. the file says "there was an error opening this document, this viewer cannot decrypt this document"
any suggestions?
Brandon
Old Jun 13, 2003 | 01:10 PM
LWillmann's Avatar
Do you have the newest version of Adobe Acrobat Reader?
I don't have my laptop with me or I would go ahead and look the numbers up for you...
Old Jun 13, 2003 | 10:15 PM
Mtrhds94Z's Avatar
I gave the p/n's he requested..
I think you need Adobe 5.0 or later....
Old Jun 14, 2003 | 03:14 AM
yeah im pretty sure i got a newer version...like 9.0 or something..all my other files open in it.
i just wanted it for future reference, in case this kinda thing happens again
Brandon
Old Jul 19, 2003 | 09:48 AM
Coop1's Avatar
Hey the link to get the camaro parts book doesn't work can someone send me a new one or tell me how I can get this.
