I need a different custom cam
Old Jan 25, 2009 | 05:36 PM
  #16
<Puck>'s Avatar
Originally Posted by 97 6SPEED Z
One possible explanation for the larger than "normal", (i.e. your 12 degrees of exhaust duration over intake duration, i.e. 236 vs 248) may be keyed to the intake and exhaust valve lifts (.608" Intake vs .578" Exhaust) that this particular cam has? They may have been trying to compensate for .030" less exhaust lift by adding more exhaust duration. The cam "guru's" play with stuff like this all the time with really no adaquate explanation to end users for their final choices.
I would guess that is because the heads exhaust port may not support airflow above a certain lift, but it can be compensated for by keeping the valve open longer. Thats why it is so important to match the cam to the heads and not vice-versa, yet people still often insist on picking off the shelf cams before they even know what heads they will be running .
I would not second guess any competent builder/machinist/cam guru with a good reputation . What they do is not something the average person can learn from a book over a weekend - years of experience and trial and error are behind their decisions, not just typing specs into a computer.
Old Jan 26, 2009 | 03:15 AM
  #17
F6's Avatar
F6
In my case, I bought the heads long before I bought the cam. I think my exhaust port flow #'s are exceptionally good, see flow #'s above. He could have picked other exh. lobes with less duration, like the 244°/.613 lift Grind # 3120. The thing is, I ordered a custom cam, which later on it turned out to be an off shelf Comp Cam!!!!
Again, I think I don't have the right cam since it is not a custom cam specifically picked out for my combo.
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
CARiD
Jan 14, 2015 04:00 AM
super83Z
Jul 11, 2002 10:16 PM
