I messed up BAD!! Every one help please
Old Jun 23, 2004 | 09:06 AM
  #16
Originally posted by Revolutionary
I didn't see it mentioned yet but did you notice that looking down into the hub it necks down to just a half inch so you cannot get the jackscrew on your puller to go all the way down to the crank snout itself? ...
That's what I have been referring to.
Old Jun 23, 2004 | 10:24 AM
  #17
Z-RATED94's Avatar
We did it Revolutionarys way last night to my car. We used a different bolt tho so as not to possibly screw up the head of the stock hub bolt.
What do you guys think about putting a small dipple in the center of a spare bolt, so that the nub at the end off the jacking screw on the 3 prong puller fits into it and stays centered. I believe this would help keep equal pressure on all three sides.
Old Jun 23, 2004 | 11:27 AM
  #18
cliff929's Avatar
I use a 3inch 7/16 20 threads per inch and screw it in a couple turns then put a short 5/16 socket on the head of the bolt and the puller bolt will stay center and not turn off and will stay centered and you wont damage the bolt head. I also use a 3 jaw puller and have had no problems.
Old Jun 23, 2004 | 09:16 PM
  #19
Fast94T/A's Avatar
Cliff how's it going buddy i bought the hatch off you.
No i wasn't trying to be defensive, I was just trying to clear things up. Sorry if it came across like that. I just went to day and bought a 30 dollar 3-jaw puller and it won't come off.
Yes if i diden't break off the flange i'd say that wiuld work. But there isn't enough ledge for it to grab on to.
My buddy here who works at A Don Marshel garage or somethin like that is gettin a bearing spereator or a cheese cutter tommarow.
Tryu agine i guess
Brake
Old Jun 23, 2004 | 10:16 PM
  #20
RCF925's Avatar
Originally posted by SLeePer350
DO NOT do that propane torch idea.....metal expands when heated as we all know, which means the crank snout will end up most likely being just as tight, you will risk deforming other parts or possibly melting timing cover seals....
anyway....go to advanced auto or autozone, whatever is there where you live and get a 3-toed pulley puller!!!!
even with only 2 good flanges, i would assume you could get the hub off...the only reason it is being so hard is because it is such a ridiculously tight fit on the crank snout, thats all
so dont do anything ridiculous and just approach this calmly...oh and make sure the crank bolt is out!! i believe it is a 7/16" fine threaded grade 8 bolt inside housed inside of the hub
When you heat with the torch the hub obviously heats up before the crank has a chance to and it will come off. You are not heating it to 2500 degrees, Just hot enough for expansion
Old Jun 23, 2004 | 10:52 PM
  #21
ninetythreez's Avatar
If you don't get it with the last puller you got, you are gonna end up having to heat it. The heat will not hurt your crank and sounds like your hub is already screwed anyways. I also stripped a 3 jaw puller on a LT1 a year ago and ended up heating it with acetyline torch to remove it. You could also take a side grinder and run it down the sides and half it, heat it a little, then knock it off. That will heat it up also though so better just to heat and pull/bump it.
Or hook one end of it to a truck and the other end chained to another truck and see how...oh,nevermind...
If all that fails I got some good stock LT1 cranks..cheap..
Old Jun 26, 2004 | 09:37 AM
  #22
Smokn '94 Z's Avatar
I told you these crank Hubs alway bite people in the ****....
Old Jun 26, 2004 | 09:48 AM
  #23
Z-RATED94's Avatar
Yes you did! I like cliff929's idea about the socket over the head of the bolt, to help keep the puller centered.
Old Jun 26, 2004 | 10:51 AM
  #24
carlos64030's Avatar
The portion of the crank snout exposed inside the hub is to small for a standard puller's beveled tip to fit into, so use a four inch long (grade 8) 5/16-inch Allen bolt that fits inside the crank threads. The beveled tip of the puller will comfortably sit inside of the head on the Allen bolt.
Old Jun 26, 2004 | 11:11 AM
  #25
You guys are sure paying a lot of money for your pullers! I paid around $9. for mine at True Value Hardware...it has pulled my crank hub with no problems at all...it even came with a few attachments. So for anyone that reads this post for future references...DO NOT PAY 230 FRIGGIN DOLLARS FOR A DAMN PULLER!
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jayblev95
Jun 7, 2015 04:04 PM
BLK1997Z28
May 7, 2015 03:01 PM
maybe2fast
Mar 13, 2015 11:48 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
