i just wanted to say (header install...long)
Old Jun 17, 2004 | 08:20 PM
simple's Avatar
what a MAJOR PITA doing LT headers is on an LT1
i've been helping my buddy do his on his '96SS and everything that could possibly go wrong has gone wrong or is going wrong LOL
it was nowhere near this hard to do on my car, of course i installed a tubular k-member at the same time i did my LT's! maybe i'm one of the smart ones
Jet-Hot LT's, he got in on the most recent group purchase they ran not knocking there headers at all tho
we had to grind on the k-member (the lip on the bulbous part that bolts to the inner fenderwell) on the passenger side as well as part of the bellhousing where the starter bolts in, so the header would slide all the way over into the position it needs to be in, oh and the trans mount was unbolted and the motor was jacked up on that side also about an inch or so and there still wasnt enuf room to get it in without grinding
now one thing i dont like is the 7/16" header bolts they supply!
why someone would supply or use these with LT 3/4" headers is BEYOND ME, they are just way too big to use
i took one and attempted to chase the threads of the 1st bolt hole under the alternator and behind the power steering pump, i got it going in less then halfway by hand) with my fingers and now i cannot get it to come back out so i can put in the allen head bolts we are using
there isnt enuf room to get a 7/16" wrench around the bolt because of the primary and the Acc. bracket, which now looks like it will have to be removed to finish this project
LMAO the drivers side header went in flawlessly! so thats one good thing
I vow to never physically help anyone else install Long Tube headers on an LT1 4th gen, however i will show up and drink your beer and point you in the right direction, just doing it from a lawn chair from now on
i needed to rant, i'm just frustrated as all gitout
anyone have any ideas other then taking the accesory bracket off, for getting theat one stuck bolt out?
Old Jun 17, 2004 | 08:24 PM
25thBird's Avatar
I feel you on that one... it just feels real good once you're done and knowing you did them yourself instead of paying...
Old Jun 17, 2004 | 10:05 PM
crazy_jackalope's Avatar
Maybe you can bend a wrench and call it your special tool. It worked when I was removing a distributor. It probably won't work but It's a thought.
Old Jun 17, 2004 | 11:45 PM
stonez96z28's Avatar
It is a bitch....I just did mine last Friday night. On the passenger side all I had to do was remove the starter and jack the engine up about 3 inches.
Old Jun 18, 2004 | 12:34 AM
madhatter's Avatar
Re: i just wanted to say (header install...long)
I said that 4 installs ago.
Old Jun 18, 2004 | 11:37 AM
LWillmann's Avatar
I ended up taking a cheap 3/8" combo wrench and grinding the wall of the boxed end to make it thinner so it would fit on the head of the bolts up next to the primaries... Worked like a charm...
Old Jun 18, 2004 | 11:53 AM
stereomandan's Avatar
Ditto, except mine was the 7/16" boxed end.
Dan
Old Jun 18, 2004 | 04:03 PM
simple's Avatar
we got it all buttoned up and drove it today
we used allenhead bolts and had to grind down the head on some of them to clear the primaries and that worked like a charm
7/16" bolts and 3/4" primaries is a PITA
after looking at and fighting with this install, its very easy to see where they could be improved upon
Cam's maro
Jan 30, 2015 09:21 PM
k1996z28
Jan 21, 2015 07:22 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Lederman1976
Nov 30, 2014 05:21 AM
