I just took my cat off
Old May 24, 2004 | 07:01 PM
Bobs 94 TA's Avatar
Good lord it's F'n loud now.
Old May 24, 2004 | 07:39 PM
Eliminator's Avatar
Good loud or bad loud?
Old May 24, 2004 | 07:55 PM
FLyinlow89's Avatar
any difference in performance? I was thinking about getting mine punched this week when i get my cat back done
Old May 24, 2004 | 08:13 PM
CamaroSS30thAnn's Avatar
loud and somewhat raspy i bet
Old May 24, 2004 | 08:52 PM
RE AND CHERYL's Avatar
Unless you gonna replace the cat with a straight pipe, don't gut it. A gutted cat will flow worse than a non-gutted cat. Go figure.
Old May 24, 2004 | 09:08 PM
Spllouder's Avatar
I agree all a guted cat is good for is loudness .
Old May 24, 2004 | 09:12 PM
scoobysnax83's Avatar
you make it sound like you're running open headers. Back when my exhaust was stock. Gutting the cat provided a perfect sound and performance boost since I believe mine was clogged a bit at the time.
Old May 24, 2004 | 09:15 PM
DaveRous's Avatar
a gutted cat WILL flow better and decrease spool up on a turbo car, I have track times to prove it, but as far as a NA goes...Not so sure, just joining the ranks. As far as im concerned though a fully gutten cat is nothing more than a test pipe and could not hender flow.
Old May 24, 2004 | 09:25 PM
Spinner's Avatar
But it would be a LOT more turbulent then with the ceramic catalyst inside. Similar to the screened/descreened MAF argument.
Old May 24, 2004 | 10:14 PM
Bobs 94 TA's Avatar
I replaced it with a straight pipe. The cat was clogged so I have to replace it.
Old May 24, 2004 | 10:23 PM
DaveRous's Avatar
Mildy more turbulet would be my call But unlike a MAS sensor i was under the impression that expelled exhaust fumes didn't need to too clean flowing. I understand a eddie type affect could occue but the added flow from the stuff packed in there should negate the affect of it(Ever seen all the **** packed in there? Looks like a wall). At least thats my call Again, just switching over to NA, so I could be wrong here.
Old May 24, 2004 | 11:12 PM
DaveRous's Avatar
Also when you gut a MAS the sensor looses directed flow and thus can make the car run like crap unless tuned. When you gut a cat there are no sensors to mess with, just a straighter line through the back.
Old May 24, 2004 | 11:24 PM
94zLT1's Avatar
i have an aftermarket 3" supercat and when i cut my exhaust off i looked in there and all it was was a honeycomb and straight pipe after that...i think it flows damn good
Old May 25, 2004 | 01:03 AM
Lower's Avatar
Good question!
Old May 25, 2004 | 01:09 AM
SoloExceptional's Avatar
When I took my cat off to put my 3" Y-pipe on it became bad loud... like "Hello officers I'm 4 blocks away accelerating quickly.. please come get me a noise polution ticket" loud.. Guess the cutout and Long tubes don't help the situation either...
