I just took my cat off
Originally posted by RE AND CHERYL
Unless you gonna replace the cat with a straight pipe, don't gut it. A gutted cat will flow worse than a non-gutted cat. Go figure.
you make it sound like you're running open headers. Back when my exhaust was stock. Gutting the cat provided a perfect sound and performance boost since I believe mine was clogged a bit at the time.
a gutted cat WILL flow better and decrease spool up on a turbo car, I have track times to prove it, but as far as a NA goes...Not so sure, just joining the ranks. As far as im concerned though a fully gutten cat is nothing more than a test pipe and could not hender flow.
Originally posted by Spinner
But it would be a LOT more turbulent then with the ceramic catalyst inside. Similar to the screened/descreened MAF argument.
But unlike a MAS sensor i was under the impression that expelled exhaust fumes didn't need to too clean flowing. I understand a eddie type affect could occue but the added flow from the stuff packed in there should negate the affect of it(Ever seen all the **** packed in there? Looks like a wall). At least thats my call
Again, just switching over to NA, so I could be wrong here.
When I took my cat off to put my 3" Y-pipe on it became bad loud... like "Hello officers I'm 4 blocks away accelerating quickly.. please come get me a noise polution ticket" loud.. Guess the cutout and Long tubes don't help the situation either...
