i just dyno'd....problems...
Old Oct 26, 2004 | 09:42 AM
glennxx1's Avatar
it was a back woods place and they just got there dyno about a week or two ago, old man operating it....first run, 175 rwhp, and 312 rwtq, 2nd run i had 210 or 211 rwhp and 280 rwtq and last run i got 215 rwhp and 278 rwtq
NOW, i just put otvc's, no trouble codes are showing, i got longtubes, CAI, cutout, no cats egr air delete......any 1 with me on thinking it was the place?
if i ran 2.36 60 ft (40 psi Z rated goodyears) 9.3 in 1/8 mile , where should my hp be at? any calculators? (thats with stereo seats etc...
and if i run again, with low psi and i saw a ... 2 flat 60 and run a 9.0 or 8.9 would i be in the 285-295 rwhp range?
Old Oct 26, 2004 | 09:45 AM
jbsupra89t's Avatar
Re: i just dyno'd....problems...
i hope something's up, cuz 215rwhp out of all those mods seems incredibly... LOW. even if it was a mustang dyno which seem to show up with lower numbers than say a dynojet...
-J
Old Oct 26, 2004 | 09:49 AM
glennxx1's Avatar
it was a mustang dyno btw...not that i think it makes 80 hp diff
Old Oct 26, 2004 | 11:02 AM
atljar's Avatar
ETs dont mean much about HP. What were your 60' and trap speeds?
Old Oct 26, 2004 | 11:19 AM
glennxx1's Avatar
well this is a good thing to know......i called carolina auto masters, they said way i did it was all wrong (usualy put it in 3rd and do the pull....) these guys got me to put it in 2nd, and drive to 90 mph that'd be my problem along with it being mustang dyno, but now my ? would be, if i got 312 max torq on first run, what might my peak torq really be ?
Old Oct 26, 2004 | 11:20 AM
LT1ponykilla's Avatar
Mustang dyno's are usually lower but not that much. A 9.3 for your mods is pretty bad! You should be running mid 8.5's 8.6's on street tires with the right launch! 9.3's is what most stock LT1's run if not a little slower!
Old Oct 26, 2004 | 11:23 AM
glennxx1's Avatar
that was with a 2.36 60 (40 psi in goodyear eagle gsc Z rated tires like i said)
Old Oct 26, 2004 | 11:24 AM
ok, say you drop to 2.0, thats still a 9.0 or maybe 8.9
LT1WanaBe's Avatar
Thumbs down Re: i just dyno'd....problems...
[QUOTE=glennxx1]they said way i did it was all wrong (usualy put it in 3rd and do the pull....) these guys got me to put it in 2nd, and drive to 90 mph that'd be my problemQUOTE]
That seems wrong to me as well, considering your 1:1 drive ratio would be 4th gear, seeing as how you've got the 6 speed trans
Old Oct 26, 2004 | 11:26 AM
they usually run the car in 4th gear for 6pds. when i had my car dyno tuned he went through the gears easy until 4th, then he ran it up to redline!
Old Oct 26, 2004 | 11:27 AM
glennxx1's Avatar
isnt the rule .1 off 60 is .2 off et? ( so .4 would be .8 off--which would put me at 8.5) set of nitto's would fix that
Old Oct 26, 2004 | 11:30 AM
good luck
Old Oct 26, 2004 | 11:33 AM
glennxx1's Avatar
greatly apreciated
btw opti was replaced 1 week after the 9.3 (it wasnt giving too much trouble at the time, just a stumble here and there)
Old Oct 26, 2004 | 11:38 AM
roadrage912's Avatar
wow dude, that does suck. technically you can dyno in any gear and they can correct the numbers, but if you dyno in your direct drive 1:1 gear ratio there is no need to correct the numbers and that's where the corrected numbers are coming from anyway. some dynos just like to be different i guess.
LT1ponykilla- a 2.36 60' is one with a lot of wheel spin. and when u throw in wheel spin, the numbers can't be figured out like normal track numbers. when i was running stock i was running 13.9-14.0 all day long. i pulled up on a C5 and got too excited and too far into the pedal and spun. i ran i think a 15.5.
there's no way with ur mods that you should be looking at 9s in the 1/8. with some tires and a nice 60' you should be seeing mid 8s.
Old Oct 26, 2004 | 11:44 AM
roadrage, you arent telling me anything I dont know. I said that he should be running mid 8's with his mods.
