I have 2 LT1's but only one set of heads, which one should I use?
Old Oct 4, 2005 | 01:25 PM
  #16
FroSSty's Avatar
Re: I have 2 LT1's but only one set of heads, which one should I use?
The lt-1 block will have a 5.7 stamped on the driverside behind the head(looking at the block from the top). It also has a 327 stamped on the driver side of the block under the head (would be behind/under the exhaust manifold). If it were my decision, I would probably put the heads on the Trans Am block. Even If you only see a few more hp. But you should check the tops of the pistons and cylinder walls to see which ones look better.
Old Oct 4, 2005 | 07:44 PM
  #17
Leader_One's Avatar
I was thinking the same thing, the transam lt1 would need a honing to be perfect and the Roadmaster would probably need a boring because it has the lip near the top of the cylinder wall.
Old Oct 4, 2005 | 08:05 PM
  #18
1996LT1NY's Avatar
Originally Posted by ChrisUlrich
LT1's are labeled 327, no?
Yes.. they have "327" on the side of the block. "5.7" can also be found in the top behind the drivers side head on the bell area
HectorM52
Jul 30, 2017 11:46 AM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
Catmaigne
Dec 25, 2014 12:16 PM
