I got my old opti out! Im almost positive this was my problem!
Old Apr 18, 2003 | 03:36 PM
  #16
Hyperspeed97z28's Avatar
when my opti died and I pulled it out it was also rattlin inside....
Old Apr 18, 2003 | 03:48 PM
  #17
Rodrigues's Avatar
Heres some pics of the broken bolt and where it broke
www.kak.com/dist
Old Apr 18, 2003 | 03:52 PM
  #18
Rodrigues's Avatar
Am I going to have to remove the timing chain cover to grind the dowel down??
Old Apr 18, 2003 | 04:29 PM
  #19
Perhaps if you are resourceful enough, you won't have to. Maybe a Dremel could do it. You would want to keep any metal from getting into the engine.
Old Apr 18, 2003 | 05:44 PM
  #20
97 SLP Company Car's Avatar
opti
Hey I just got my opti ouy . I also have a small amount of play, side to side, movement in the bearing. No in and out movement thou. How the sh** do you get this thing apart? What socket because I know I dont have one for that.
ROD keep updating, cause I'm only like 25 miles from you and I'd like to know if your getting your parts locally, Good luck
Old Apr 18, 2003 | 08:03 PM
  #21
Don 97 SS's Avatar
Re: opti
It takes a female Torx E4 size socket. I had to grind the neck on my socket to narrow the diameter to get it to fit into the recess of opti cap to reach those weird bolts.
Old Apr 18, 2003 | 08:04 PM
  #22
Rodrigues's Avatar
Re: opti
I get my parts from Combination motorsports or Jason Cromar... I wouldn't open the opti unless you know its bad. I just took a vise grips to the bolts . The opti costs $195 like I mentioned earlier from Jason and you will need the waterpump gaskets as well as the two O rings for the opti.
I had no intention of "repairing" the opti but I was just extremely curious what was rattling around inside of it.
Old Apr 18, 2003 | 08:24 PM
  #23
done
I got it apart and all I found was a really worn out rotor and cap everything else looks like new. I could see a trace of arcing though but i'm sure thats wires or plugs.Do we have to go to dealer only to get new cap and rotor?
Old Apr 18, 2003 | 08:34 PM
  #24
Rodrigues's Avatar
Re: done
If your opti died, I would just buy a new one
1995-1997 distributor cap and rotor
ACDelco #D8301 10457293 $106.85
I think what dies in an opti is that black sensor...
Old Apr 18, 2003 | 09:10 PM
  #25
drewstealth's Avatar
My car is still misfireing and the SES light is still on. I changed the plugs and wires and it didn't really help. The shop said its my #3 cylinder. I checked the spark on it and it was a lot weaker then it was on my #1 cylinder. So i'm guessing it is my opti. The car only has 50,000 but i don't know what else it can be. What part actually is the opti? Is it the distributor? Also is the cap and rotor seperate from the opti?
Old Apr 18, 2003 | 09:11 PM
  #26
CamaroSS165's Avatar
What is Jason's phone #? I"ve got the same problem.
took off the opti and it sounded like a box of bolts when you shake it and scrapes when you turn it.
So you guys think the dowel pin on some of comps
cams are too long. I just installed a xe236/242 about 2 months
ago.
Old Apr 18, 2003 | 09:12 PM
  #27
Rodrigues's Avatar
If you didnt cut your dowel when installing the comp cam, then yes it is probably your problem...
1104032 - Vented Opti ~ $195
(2) 10128343 - Waterpump Gaskets
12553792 - Waterpump driveshaft O ring
(2) 10474278 - Opti to camshaft bushing
10217886 - Waterpump seal
Jason Cromer: 877-726-8295
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Old Apr 18, 2003 | 09:31 PM
  #28
Unhappy
Thanks for the info. on Jason and no i did not cut the damn pin
down. just sucks to be me.
the pin did cross my mind but a guess it kepted on going.
Old Apr 18, 2003 | 09:35 PM
  #29
I would check that wire with a meter to be sure there was not something wrong with it-new or not.
Old Apr 19, 2003 | 12:59 AM
  #30
Yeah i guess i better do that this sunday. Before i go out and spend a money on a new opti. But can somebody please explain to me what the opti actually consist of and what people replace when they get a new one.
