I give up!
Old Aug 11, 2005 | 10:13 PM
Heatmaker's Avatar
Advanced Member
I give up!
Lately my when you go t o start my car... it triggers the ignition coil... then attempts to turn over.... then nothing... then you try again a few moments later it will click... turn over then put put put.... and start roughly.... it will idle roughly... then drop down to 800... then pick up to 900... then drop to 800... the idle smoothly.
Then there's times you jump into the car and start her up and it just starts right up liek normal with no problems.
I've changed the Starter
new ICM
VATS has been programmed out
New Coil
New Wires
Good juice at battery
New Ignition Switch
leaves me with a WTF scenario...
I'm so done trouble shooting open to any suggestions...
I'm really at a brick wall with this one.
Old Aug 11, 2005 | 10:33 PM
ZMAN Z28's Avatar
Re: I give up!
Slim chance it might be a broken valve spring. Just a thought.
ZMAN
Old Aug 12, 2005 | 10:22 AM
Heatmaker's Avatar
Advanced Member
Re: I give up!
My car would of exploded by now...... but that would be a good excuse for a cam swap.
Old Aug 12, 2005 | 10:43 AM
LT4orbust's Avatar
Re: I give up!
fix the cranking problem first, it sounds like poor amperage to the starter, do you know how to do a voltage drop test
Old Aug 12, 2005 | 10:45 AM
Bersaglieri's Avatar
Re: I give up!
Honestly that is exactly what my car did when it wasnt getting gas to the engine. I was low on gas and on a incline just right that it couldnt get the little bit left in the tank. So whatever you might think would keep gas from getting there occasionally. Fuel filter, line plugged up, injector clogged, etc.
-Dustin-
Old Aug 12, 2005 | 12:51 PM
RedLT4Mike's Avatar
Re: I give up!
Have you checked your fuel pressure?
Old Aug 12, 2005 | 01:21 PM
Heatmaker's Avatar
Advanced Member
Re: I give up!
Yeah... I have a Autometer guage installed on there.. fuel pressure is fine... 43psi
I changed out the filter too...
Today she acted normal.
My starter wire was burned out... becasue of the header... and I repaired it.
The injectors are new...
It's hard to pin point because when it runs it runs normally and starts up normally... but out of no where when you turn it on.... it gives you hell and heartache.
I might test the battery out... I get good amperage... but there was a time when it was drained down to 9volts and I don't know why.... it's an optima at that... so...???
Old Aug 12, 2005 | 01:23 PM
BUBBA's Avatar
Re: I give up!
Get a new battery.
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Sep 18, 2015 03:46 PM
