I done a Very Bad thing
Spun the bearing.
In oil filter I saw little shiny fearings
Got it towed to ARE they say I will need this
Forged Piston ............................$520 $390USD
Rings ........................................$200 $150 USD
Bearings.................................... $150 $75USD
Oil Pump & Shaft .........................$100 $75USD
Timing Gears & Chain ...................$156 $119USD
Balancer ................................... $250 $187USD
Heads (Cleaning) .........................$350 $265USD
Crank Shaft Core (Stock) ..............$350 $262USD
Rods Bolts ..................................$100 $700 USD
Resize Rods ..................................$80 $60USD
Disassamble and Assambe ............ $750 $562USD
Renry (Putting a motor in and out) $1000 $750USD
BTW its CDN which comes to $3420 USD
Any thoughts
Engine still seal
They out of what they saw from Oil Filer
Any inputs
Crate Motor ?
Jordon Musser or Shawn Salzar!
Updated for US prices
Any thoughts
Engine still seal
Any inputs
Crate Motor ?
Get a shortblock, pref. a 4-bolt. Have cam of choice installed. New lifters, etc.
I'd be a bit leery of a complete rebuild unless you are REALLY sure that the builders will do a good job.JMHO
Want reliability, get a stock motor. Not trying to be smart, but you can't get more reliable than the stock parts. I wouldn't go to ARE unless I wanted a nitrous motor.
I would seriously consider finding a stock shortblock and just transferring your stuff onto it.
Ryan
Ryan
My good friend said this
Rotating assembly $800.00 to $1800.00 (depends on crank forged, rods used &
hyper. or forged pistons) (Check with Ohio crankshaft-they advertise in
National dragster)
Get valve job, do a 3 angle $150.00-250.00 for both.
Block machine work; cleaned, bored 30 over, align-honed for new crankshaft,
decked & cam bearings installed. $600.00
Put motor together $200.00-300.00
Gaskets & misc. $200.00-250.00
Labor to R & R motor (Factory warranty time on a manual trans car is 12.5
hours, for customer pay labor multiply by 1.3 which is 16.3 hours of labor
times whatever labor rate they have there)
Hope this helps.
Or you could just have them inspect crank & if ok just replace bearings &
oil pump.
Keith
National dragster)
Hope this helps.
oil pump.
Keith
I had a 383 built for less than that. I'm not saying you should build a 383 but I had to buy a new crank, forged rods, and forged pistons and had the extra machining done and it still costed a bit less or the same as that including removal and installation of engine.
Their labor looks right on..... Check my post on TC.
darn canadian prices... eh. Can you correct all those charges to the american dollar so that a more accurate comparison can be made?
even if monoply money(candian bucks
) some seem high.. ie
Rings, $100 US
why would you need a new balancer?
stock crank shaft.. i see them go for $100 full cleaned up and polished
350 to clean the heads? hot tanking should be like $20
rest seems ok.
) some seem high.. ieRings, $100 US
rest seems ok.
Any of you guys wants to Check out Toronto ?
lodging (motel or my place) FREE
Beer Free
TICKET (can talk
)almost free
Get to see Paki-Texan Mir Free
Get to hear my Accent Free
To work on my Car for Free and my thanks to you
Beer Free
TICKET (can talk
)almost freeGet to see Paki-Texan Mir Free
