i burned my fuel pump up tonite what pump should i get aftermarket or stock
I bought mine from here Auto Performance Engineering. An OEM replacement is quite a bit more if I remember correctly. Plus, with the aftermarket one, it will handle most major mods. you may have planned for in the future.
Not sure on labor cause I installed it myself. But do a search, and you should find more info.
Dave
Dave
I would darn well make sure it is the pump before getting into it, because it is gonna cost you plenty of bucks to have someone do it. I have seen costs posted on this board ranging from $500 to over $1000.
Depending on your future mods I would recommend going with a 255 lph intank if you plan on serious mods in the future. As far as cost go I would recommend doing it yourself. It is not hard but just time consuming.
Jul 4, 2005 05:00 PM
