I bought a moser 12 bolt used...
Old Aug 13, 2003 | 06:37 AM
simple's Avatar
it was off an LS1 car that had 4 channel ABS, my car a '97 only has 3 channel ABS, no traction control, what can i do to get rid of the ABS stuff on the rear and how do i go about doing it? just get the reluctor rings taken off the axles, or leave them on there and get rid of my ABS all together? can I delete just the ABS controls for the rear end? all ideas and help is greatly appreciated
thanks
Steve
Old Aug 14, 2003 | 07:46 AM
simple's Avatar
bump
Old Aug 14, 2003 | 09:14 AM
quicksilver97ta's Avatar
I dont know the best solution for your need but just to go by what I do know: The 3 channel ABS system uses a reluctor ring on the carrier so if there is no provision for this you'll probably have to loose the ABS as it is. However, there may be a way for you to convert your car to a 4 channel system but good luck. Contact Moser, maybe they can provide a solution. I think the easiest and probably cheapest thing would be to have the ABS programmed out of your PCM.
Either way heres a bump for ya.
ddr698
Jan 9, 2015 10:05 AM
Wicked
Jul 7, 2003 01:28 AM
Wicked
Aug 22, 2002 12:37 PM
kev93z28
Aug 19, 2002 12:48 AM
