i am looking for a rpo and vin decoder
Old Jul 31, 2003 | 12:49 AM
cals400ex's Avatar
i know www.thirdgen.ord does this for the 3rd gen's but i don't know where i can find the rpo and vin codes for a 4th gen. does anyone know where that can be done?
Old Jul 31, 2003 | 08:56 AM
Decode the VIN
There are many sites that have RPO codes. http://duzy.8m.com/motherload.htm has quite few, though not all specific to the 4th gen.
Here is a pretty typical list for a black 1995 Z28:
AG1 : ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AK5 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU0 : LOCK CONTROL, REM0TE ENTRY
AU3 : LOCK CONTROL, SIDE DR, ELEC
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DL5 : DECAL, ROADSIDE SERVICE INFORMATION
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
FE9 : CERTIFICATION EMISSION, FEDERAL
GU5 : AXLE REAR, 3.23 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
IPB : TRIM- INTERIOR DESIGN
J1F : BRAKE PROVISION SPECIAL TO SUIT FOREIGN REGULATION
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
KG9 : GENERATOR, 140 AMP
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
LT1 : ENGINE, GAS, 8 CYL, 5.7L, TPI, HO
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
M30 : TRANSMISSION-AUTOMATIC 4-SPEED,4L60-E, ELECTRONIC
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N96 : WHEEL, 16 X 8, CAST ALUMINUM
QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
R7A : CONTROL SALES ITEM #26
R8S : CONTROL SALES ITEM
STE : PLANT CODE - St. THERESE, PQ, GM OF CANADA
T96 : LAMP, FOG
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
U1T : RADIO, AM/FM STEREO, SEEK./SCAN, COMPACT DISC,HPS, CLOCK, ETR
U65 : SPEAKER SYSTEM, 6, DUAL FRT DASH MTD, F/D, DUAL
U73 : ANTENNA, FIXED, RADIO
VK3 : LICENSE PLATE, FRT MOUNTING PKG
VM3 : LABEL INFORMATION, CONSUMER CONTAINS BPR IMP STANDARD
V73 : VEHICLE STATEMENT,US/CANADA
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY : STOCK ORDER PROCESSING CODE
1SK : PREFERRED EQUIPMENT GROUP
12B : TRIM COMBINATION,CLOTH, GRAPHITE
12I : INTERIOR TRIM, GRAPHITE
41Q : MOLDING COLOR, BLACK
41U : PRIMARY COLOR, EXTERIOR, BLACK
6HD : SPRING, COMPUTER SELECTED, FRONT, LH
7HD : SPRING, COMPUTER SELECTED, FRONT, RH
8TH: SPRING, COMPUTER SELECTED, REAR, LH
9TH: SPRING, COMPUTER SELECTED, REAR, RH
Old Jul 31, 2003 | 10:59 AM
87transam383tpi's Avatar
does anybody have a RPO decoder with production numbers? i'd love to see that.
Josh
Old Aug 1, 2003 | 12:50 AM
cals400ex's Avatar
thanks rob!!
Old Sep 5, 2003 | 12:26 PM
camarosource's Avatar
Hello,
We offer both a RPO decoder (Decodes over 4400 GM RPO Codes), and a VIN decoder (1967 - 2002) which not only decodes it, but also verifies your Check Digit (1981- 2002) code and reports if invalid, and allow you to conveniently jump to the yearly info database for that year.
http://www.camarosource.ca/main_new_..._selection.htm
Select the generation, then the year. Once the database loads (over 800 pages with over 600 Camaro variations), select "Decoding".
easter123
Sep 26, 2015 08:39 PM
RobFlag
Aug 29, 2015 11:40 PM
ews54
3rd Gen / L98 Engine Tech
Oct 13, 2002 03:47 PM
Caps94ZODG
Aug 5, 2002 06:31 PM
CAJUN-Z
V6 Tech
Jul 25, 2002 10:24 AM
