Hypertech shift points question (A4)
Old Oct 5, 2005 | 10:19 PM
boyd's Avatar
I was just wondering if I should make any changes up or down with my hypertech programmer to my shift points?
My car is basicly stock except for the usual bolt-ons that most people do, no internal work has been done or power adders.
In my opinion, there is no need to make it pull higher if it runs out of pulling power before the 5700 (factory setting) mark, right?
Old Oct 5, 2005 | 11:14 PM
Re: Hypertech shift points question (A4)
The only real way to see if it is of any benefit for your particular car, would be to play with it at the track where you could get good comparative test results.
Old Oct 6, 2005 | 11:29 AM
RedRyder518's Avatar
My past experiences with raising the shift points is actually slower times for me. However, when I race the eigth, my car always shifted into 3rd about 50 feet before the end so I raised my shift point to make sure it stayed in 2nd all the way through the run. I gained a little time doing that but I really think that is because it was staying in gear instead of shifting. I doubt you will gain anything raising the points with a stock motor, but as shoebox said, the only real way to figure out is to do some testing at the strip.
Old Oct 6, 2005 | 10:14 PM
boyd's Avatar
I understand .
I guess I will just have to test and tune, huh ?
jb4xx
Feb 2, 2015 10:00 PM
cmdeshon
Dec 27, 2014 10:06 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
SLIMJIM
Jan 7, 2003 11:06 AM
