Hypertech Programmer III
Old Nov 28, 2013 | 01:01 PM
poposhad's Avatar
I recently purchased a used Hypertech Programmer III that is for a 96 camaro but I have a 94 which I was told it wouldn't work even with an adapter. I want to sell the programmer but I want to be sure it works. Obviously I can't tell if its locked but my concern is that when I installed the battery and turned it on without having it connected to a vehicle it would go through its start up but would freeze after it is looking to communicate with the vehicle. I can't turn it off or reset it othe than disconnecting the battery. Is that normal. Thanks
Old Dec 24, 2013 | 04:21 PM
vettlarry's Avatar
Re: Hypertech Programmer III
I have a used Hypertech for a 1994 #30026. It has the OBD1 connector so it will work for your 1994. I have a 1995 Camaro which has the OBD 2 connector so the hypertech I have will not connect. When I start mine up it goes thru the start up and then looks for the vehicle connection. Without being hooked up it just times out and shuts off. The Hypertech site says I need a # 345752. I do not think my 1995 car has the OBD 2 PCM and my guess the difference between the 1994 and the 1995 is just the adaptor. Does anyone know if the adaptor is the only difference?
Old Dec 24, 2013 | 04:35 PM
Yes.
http://shbox.com/1/xraycable.jpg
Old Dec 25, 2013 | 11:36 AM
Chimera96's Avatar
can't use a OBD2 programmer on a OBD1 car
Old Dec 25, 2013 | 12:30 PM
He understands that. That's why in his first post he indicates he is selling it. He wants to know how to determine if it works, so he can be honest when selling it.
colts0455
Sep 4, 2015 01:41 PM
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
colts0455
Jul 24, 2015 04:51 PM
SLIMJIM
Jan 7, 2003 11:06 AM
