Hypertech AFPR users!!
Old Jan 24, 2004 | 01:27 AM
Fastbird93's Avatar
First, I scoff at their directions to "pull the fuel pump fuse and start engine. Let run until it dies. Ok, I like the fact that they have you pull the fuel pump fuse so you bleed pressure, but you should be able to bleed your pressure off via the pressure relief valve located on most fuel pressure gauges. I just don't like the idea of letting the engine die staving of fuel.
Second, when adjusting the pressure, the directions say: "turn the adjusting screw (a small allen screw located down inside the vacuum hose port on the regulator) clockwise to increase pressure, or counter-clockwise to decrease pressure." There doesn't seem to be a small allen screw in the vacuum port, but there IS a scrwe sticking out of the end of the regulator. Is this the screw??
Old Jan 24, 2004 | 05:38 AM
Don 97 SS's Avatar
They probably provide that goofy method based on recommendations from HyperTech's attorneys. They want to avoid lawsuits from fools that create engine fires due to splashing fuel on the engine using the easy method you describe. I used your method
CLockwise increases FP. Yes, that allen screw you identified is the right one.
Old Jan 24, 2004 | 09:59 AM
Fastbird93's Avatar
It's not an allen screw though. It's a normal six point screw. That's the one though?
2QUIK6
Sep 17, 2016 02:31 PM
96SilverRam
Aug 9, 2015 04:15 PM
colts0455
Jul 24, 2015 04:51 PM
JCSWS6
Jul 19, 2015 06:47 PM
mrwz28
Jul 8, 2015 09:11 PM
