Husrst shifter
Re: Husrst shifter
Is the shifter really hard to push to the right to enter the "reverse" shift gate? Or does it move freely to the right, but become difficult to move when you try and move the lever into 6th?
Which Hurst do you have - GM version from the "SS", Competition +, or Billet?
It could be a chance the shifter ****- shaft is bolted on the wrong side. I switched sides on mine when I put my 5.0 in as it was getting into the side of console area. If your rubbing into the side might be worth a look
Posted from Camaroz28.com App for Android
Re: Hurst shifter
As noted in a post above, check the reverse lockout solenoid.
CARiD
Sep 7, 2015 08:21 AM
