HUGE 383 problems!! Please help.
Old Feb 11, 2004 | 09:13 AM
  #16
CCCCCYA's Avatar
Very possible. Even that little bit of running while it was in a bind would have been enough to kill the pump (too much pressure in the wrong direction).
Good luck with it from here man.
Dave C.
Old Feb 11, 2004 | 09:14 AM
  #17
Newbie97's Avatar
I had the same problems after my cam and TC install. I didnt have the noise you describe but my car didnt move much either. I drove it around the block and it didnt come out of second gear. Problem was solved by adding more fluid to the tranny. I thought I had enough but didnt. When you do TC changes that happens. Check the fluid again. Hope you fix it.
Old Feb 11, 2004 | 12:00 PM
  #18
stroked383ta's Avatar
what about overfilling it? would it have that effect? would it be safe to drive it to a tranny place?
Old Feb 11, 2004 | 12:43 PM
  #19
i turned on the car today and i noticed the fuel pressure was a 80 psi. i tried adjusting the afpr and didnt want to go down. i dont smell any gas. pcm4less did my programming. is that too rich? could it be that?
liamcg97
Nov 25, 2019 05:55 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
canbaufo
May 17, 2015 10:35 AM
Dec 17, 2014 11:00 AM
