which Hub?
Old Sep 4, 2006 | 12:38 PM
BadAssed93Z's Avatar
which Hub?
im going to order a new keyed hub for my 93. but thunder sells 2 for the LT1. the longer is for the 93 - 95's. the shorter is for 96 + 97's. but if ive upgraded to the new vented opti witha newer timing cover from jason cromer. im not sure which hub to get. any ideas.
also the stock hub worked fine and didnt leak, but since they offer both sizes i want sure because of the new timing cover.
any help would be great.
Old Sep 4, 2006 | 12:54 PM
Dave89IROC's Avatar
Re: which Hub?
the shorter hub is for the OBD2 cars with the crank sensor reluctor
so you need the 93-95 one
Old Sep 4, 2006 | 01:02 PM
OBE1 95Z28's Avatar
Re: which Hub?
Dave89IROC is correct. The reluctor acts as a spacer as it is slide over the crank snout inside the timing cover. Therefore you need the shorter 96 - 97 hub.
Old Sep 4, 2006 | 01:07 PM
Re: which Hub?
thanks Dave i wasnt sure if that was the reason or if it was the difference in the timing covers. good to know though
thanks again
AviatorDave
Dec 19, 2016 06:35 PM
Boss002
Jan 20, 2016 12:17 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
cyteone
Feb 7, 2015 06:04 PM
