http://www.eportworks.com/lt1.html....anygood?
Old Oct 23, 2007 | 07:29 AM
  #31
97WS6NY's Avatar
Lloyd does excellent work, and on top of that he is extremely helpful. He is always willing to take the time to answer questions, give advice, and generally help you out. I would not hesitate to use him again in the future. Between him and brett I got alot of critical and useful info, and some top notch work.
BTW my package is Lloyd Ported Trickflow heads and ported intake manifold, and a bigger version of the LE3 cam.
Old Oct 23, 2007 | 07:41 AM
  #32
Nitelite's Avatar
Originally Posted by mdenz3
If I had the money, my heads would be in Lloyd's shop right now.
+1... after finishing bolt-ons you either move to h/c or power adders... and Lloyds site was the first thing I found when searching the site. My only problem is deciding from LE1 or 2... blah damn middle-class wages!
Old Oct 23, 2007 | 08:37 AM
  #33
SS MPSTR's Avatar
Originally Posted by tnmotown
i live in cali, screw emissions!!!!! lol
until you get sent to the referree. doh!
Old Oct 23, 2007 | 08:40 AM
  #34
SS MPSTR's Avatar
Originally Posted by Mtxz453
It seems like some members such as z rated94 running the le1 package is getting similar or better track times/hp as the le2 packages. Is that because of supporting mods?
supporting mods AND a commitment to make it run right. that means doing all the little things and making sure the details are correct - not a slam on anyone, but there are a lot of guys who throw parts at cars without knowing what they are doing, and expect results automatically. the guys who run the killer number have a ton of time and trial-and-error processes into their rides.
Old Oct 23, 2007 | 08:43 AM
  #35
Z-RATED94's Avatar
even though it was an under-researched question its cool to check out everyone's sig's checking out what kind of things they have on with what kind of lloyd elliot package they got and then to see how they performed. It seems like some members such as z rated94 running the le1 package is getting similar or better track times/hp as the le2 packages. Is that because of supporting mods? im a little confused, shouldn't the le2 packages provide a significant advantage over the le1?
Actually my heads where before Lloyd started using stages. But I think they would be considered LE2s. The cam on the other hand is a tad smaller than the LE1 I believe. At the time Joe O. was working with Lloyd and I asked for a cam that would pass emissions if needed. I have not had to try passing though since the car is now emissions except.
Old Oct 23, 2007 | 09:12 AM
  #36
sandman2100's Avatar
yeah, I found out about that new rule here in Illinois 2 days after getting my 97............. SUMBITCH!
Old Oct 23, 2007 | 11:53 AM
  #37
Mtxz453's Avatar
So in theory you could be pulling significantly larger numbers with the LE2 cam right?
Old Oct 23, 2007 | 12:10 PM
  #38
Z-RATED94's Avatar
Yes I guess you could, and it has crossed my mind. But I wish you could take a ride in my car and feel how tame it is for the #s it runs. For example, doing 55mph in overdrive, I give it just enough gas that it doesn't kick down to third and it still accelerates much better than when it was stock and would have to down shift. Plus with some more work, as in a decent trans and fine tuning the nitrous, this thing should run some very low 11s, no problem. Some may think I'm dreaming, but I have been doing this long enough to know what's possible and what's not.
