http://store.summitracing.com/default.asp?target=department.asp&d=15&x=8&y=14
Old Oct 7, 2003 | 08:30 PM
whitedakota's Avatar
will the set of 3.73's with the 2 series carrier work in my 95 Z 28?..i have the stock rearend, and 2.73's right now.
RMG-4900071 is the part number.
thanks alot,
steve
Old Oct 7, 2003 | 11:00 PM
i know its not the driveline forum...but people seem to respond better on the engine tech...and i know you guys know your stuff.
sorry to bother,
steve
Old Oct 7, 2003 | 11:34 PM
kmook's Avatar
Advanced Tech Moderator
This http://store.summitracing.com/partde...=RMG%2D4900071 ?
As far as i can tell thats what you need. You could double check with summit, as they have good support and can get the part you need.
Old Oct 8, 2003 | 07:40 AM
thermwood1's Avatar
If your car is driven daily or on the highway at all, i would not recommend Richmond Gears. They will make more noise than any other gear set.
I would check with Motive, Precision, or Strange for a 3.73 for 2 series carrier.
My .02
Old Oct 8, 2003 | 05:44 PM
ok thanks alot..but a set of gears that requires a two series carrier will work in my rearend right?
and i know what you mean about the richmond "wine" ...my buddy has a set in his 87 iroc.
thanks alot,
steve
Old Oct 9, 2003 | 07:19 AM
thermwood1's Avatar
Yeah, just be sure that your 3 series gears are made for a 2 series carrier.
Basically the ring gear is thicker so it will work.
Old Oct 9, 2003 | 10:19 AM
you say the ring gear is a little thicker...then if i were to get some with the ring gear not as thick, i could make the difference up with a ring gear spacer right?
thanks again,
steve
Old Oct 9, 2003 | 10:57 AM
ishz28's Avatar
My car still has a 2 series carrier and I bought three series gears. The difference in size is more than a little, it's a decent amount. I had to reorder 3.73's in 2 series, becuase they were no where near fitment.
Old Oct 9, 2003 | 12:51 PM
'93 Z28's Avatar
I have had the Richmond's for about 10,000 miles so far and no whine at all. The key is in the setup. And, the Richmond gears are cut a little sharper and a little stronger. Get them, you won't be disappointed. Just make sure you toke them somewhere that knows what they are doing.
Jay
blmw
Jun 14, 2015 05:20 PM
TitoPR221
May 26, 2015 12:20 AM
aBrotze
Advanced Tech
22
May 15, 2003 12:03 PM
97TA-WS6-Con
May 5, 2003 04:48 PM
guionM
10
Sep 8, 2002 11:08 PM
