HP on stock bottom end
Old Mar 29, 2004 | 09:35 PM
TireMarx723's Avatar
Guys with stock bottom ends, what are your HP and Mods. Im lookin to see what the max I can push the LT1 to without a rebuild. Example, Simple bolt ons, Heads, Cam, anything on a stock bottom end. Id like to see around 400rwhp, show me what your runnin! Thanks
Old Mar 29, 2004 | 09:38 PM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
See the sig. Supercharged of course. Stock bottom, rings went.
Old Mar 30, 2004 | 03:21 AM
Steve in Seattle's Avatar
One guy here (in the NW) has been running with 400+ rwhp on a factory bottom-end for the past year... through an automatic.
Daily driven and track duty in the summer.
From a durability standpoint, he probably won't get 200,000 miles out of it of course, but that's the price you pay for playing on the wrong side of 6-grand. Personally my stock engine (CAI & air foil) put down 280rwhp through my 6-speed at 100,000 miles. Pushing 170,000 right now without problems. (factory optispark included ).
Old Mar 30, 2004 | 03:23 AM
Oh yeah... almost forgot: that's 400rwhp NA, no boost or juice.
new injectors, heads, cam, PCM tune, of course... but nothing you need to pull the engine out of the engine bay for.
Don't even consider NA power levels like this on a 350 unless you have HUGE heads, a giant cam, and an amazing PCM tune. I belive he runs a 3500 stall.
Old Mar 30, 2004 | 05:57 AM
1982z28with18s's Avatar
I just put down 387rwhp with a base tune and 5 degrees of spark retard, and a small cam(~220/226) on stock bottem end through an automatic. With some more tuning it'll be at 400. Stock bottem end has 34k miles on it, gets daily driven 80 miles/day, and just netted me a 12.1 first time down the strip. Call up Lloyd Elliot and get your heads/cam and you'll be at 400rwhp no problem.
Old Mar 30, 2004 | 08:32 AM
DJ:BOTA's Avatar
Nice times!
Old Mar 30, 2004 | 08:54 AM
SAR2K's Avatar
450 rwhp with locked converter, 420 unlocked. All motor.
All the standard bolt-ons, hooker LTs, etc... ported factory LT1 heads (1.94/1.50), big hydraulic cam. Not a daily driver, but does drive VERY well on the street.
And that's a bone stock short block.
Steve...
Old Mar 31, 2004 | 12:35 AM
Steve...
Didn't I read you just had problems with your motor? Or maybe that was someone else.
Old Mar 31, 2004 | 07:50 AM
SAR2K's Avatar
Yep that was me. A damn spark plug dropped its center electrode down into the #6 cylinder. All that ceramic material does wonders to the cyliner...
Steve...
Old Mar 31, 2004 | 11:02 AM
Grease's Avatar
I've had 405rwhp on the stock bottom end for over a year now. Heads, big hydraulic cam, 11.9:1 compression and I drive it hard everyday except in the winter. I usually take it up to 6800rpm. Some people are lucky, others loose thier bottom end with just a cam.
Old Mar 31, 2004 | 11:30 AM
btchincamaro's Avatar
Thats impressive numbers for that small of a cam. What kinda head work and headers are you running with that?
Old Mar 31, 2004 | 02:32 PM
SAR2K's Avatar
Question
Originally posted by Grease
I've had 405rwhp on the stock bottom end for over a year now. Heads, big hydraulic cam, 11.9:1 compression...
How'd you squeeze 11.9:1 out of a stock bottomend?
Old Mar 31, 2004 | 02:36 PM
LT4POWR's Avatar
Lots of milling, I think. I believe his heads had to be re-ported (fixed)
Old Mar 31, 2004 | 02:48 PM
Grease's Avatar
Have your heads milled down to 50.5cc combustion chambers and use thinner headgaskets
Old Mar 31, 2004 | 02:49 PM
97SS0594's Avatar
i dropped a rod through the oil pan and i have simple bolt ons, and i was sprayin.
