Hp loss with 7' knock retard?
Old Jul 1, 2003 | 08:39 AM
HungryT/A's Avatar
Question Hp loss with 7' knock retard?
Guys,
How much HP am I losing approximately with 7 degrees of knock retard during a WOT run?
Old Jul 1, 2003 | 09:53 AM
CANTONRACER's Avatar
Varies, I guess about 20 rwhp.
Is this real knock or false knock? Try good gas, octane booster, make sure nothing is rubbing (exhaust, etc)....
Old Jul 1, 2003 | 10:21 AM
HungryT/A's Avatar
Phew, 20rwhp is a lot to be wasted in such a way...
I pretty sure it's false, the car has just basic bolt-ons, and there was no timing added in my PCM programming...
I've run race gas and the knock counts haven't changed a bit. Besides that I have a poorly fabricated, sh*ts loud cat-back.
Thanks for your input!
Old Jul 1, 2003 | 10:23 AM
With reprogramming you can change the way your car deals with KR. You can have it pull less, faster attack of decay, just get rid of it, or desensitize it some.
Old Jul 1, 2003 | 11:04 AM
96 WS6's Avatar
lol your sig just says 'cat back', you would never look twice Did you try an LT4 KM??
Old Jul 1, 2003 | 11:49 AM
Hotwire's Avatar
try checking the knock sensor itself
jack the car up, pull the wire harness off, have someone turn the key to the on position without starting the car, you should have +5 volts +/- 10%, if you have the power there, put one side of a ohm meter on the case of the knock sensor and another to the block to see if there is any resistance. if there is, try tightening up the knock sensor. then measure from the middle pin in the knock sensor to ground. You should have anywhere from 3300-4500 ohms (OBD1 sensor, OBD2 sensor is diagnosed the same way but reads around 100,000 ohms). If it's out of that range, replace the knock sensor. but watch out, it is double duty as a plug for the coolant on that side of the block and will unleash a tide of coolant straight into your face if you aren't ready for it!!
good luck.
Old Jul 1, 2003 | 02:27 PM
HungryT/A's Avatar
Ion (Madwolf - www.madz28.com has done it for me already...
Old Jul 1, 2003 | 02:39 PM
HungryT/A's Avatar
Thanks for the input guys!!
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
