HP Gains on this Maro
Old Sep 8, 2005 | 08:13 PM
35annivGT's Avatar
My friend just got this Camaro and i was wondering what HP he has and how much there is to the wheels. Trying to give him an estimate before he takes it to the dyno. Here is the info.... Btw im new to the board and as my name says i dont drive a Camaro
1993 Camaro z28, LT1 - 35,000 miles
COMP CAMS CUSTOM CAM
AIR FLOW RESEARCH HEADS 68CC
MORRISSON BEARINGS 1.5MM 2MM
2.02 1.60 STAINLESS STEEL VALVES
11.0:1 COMPRESSION GASKETS
COMP CAMS 1.6 ROLLER ROCKERS
MOTORSPORT 24LB INJECTORS
BBK 58MM THROTTLE BODY
SLP DUAL COLDAIR PACKAGE W/K&N FILTERS
SLP 1.75 INCH HEADERS
MSD 6AL IGNITION WITH TIMING SENSOR
MARCH UNDERDRIVE PULLEYS
4.10 RICHMOND GEARS (brand new)
ACCEL 8.8MM WIRES THERMO-COATED 9000 EXTREME
DYNOMAX EXHAUST 2.5 INCH WITH CHROME TAILPIPES
FUEL PRESSURE REGULATOR
Z INDUSTRIES CUSTOM CHIP
GRANATELLI TOWER BRACE AND SUBFRAME CONNECTOR
MSD RPM ACTIVATED SWITCH
Spec Stage 2+ Clutch (brand new)
EIBACH DRAG SPRINGS
FELFRO UPPER AND LOWER GASKETS
3 WIRE O2 ADAPTER HARNESS AND SENSOR
TAYLOR IGNITION WIRE SHIELD KIT
AUTOMETER GUAGES
SPEEDLINE 17 BY 9.5 WHEELS
DUNLOP 275/40/17 D40 M2 TIRES
Old Sep 8, 2005 | 08:19 PM
sw89lt1's Avatar
Re: HP Gains on this Maro
hard to even take a guess without cam specs. but i would say atleast 360rwhp.
Old Sep 8, 2005 | 08:32 PM
35annivGT's Avatar
yeah these are the Cam specs
width 534/544 duration 210/220
Old Sep 8, 2005 | 08:42 PM
sw89lt1's Avatar
all those mods and no headers
Old Sep 8, 2005 | 08:45 PM
35annivGT's Avatar
EIBACH DRAG SPRINGS
AUTOMETER GUAGES
yeah they are right there...
Old Sep 8, 2005 | 08:51 PM
sw89lt1's Avatar
my bad. that cam is fairly small so i still say 360-370ish
Old Sep 8, 2005 | 10:25 PM
1racerdude's Avatar
With 68CC chamber's it's a wonder it runs,unless it has dome pistons.
It don't have 11-1 with 68CC's and factory height block and piston's down hole .020 and a .026 gasket.My figures say it has a 7.4-1 static compression.
Did I miss something?
Kinglouui
May 26, 2016 11:05 AM
Nutty's96
Dec 21, 2015 06:25 AM
colts0455
Sep 22, 2015 02:03 PM
colts0455
Sep 2, 2015 12:41 PM
jwade88
Jun 14, 2015 09:38 PM
