How's this Opti look?
Old Sep 11, 2007 | 06:38 PM
z28 justin's Avatar
So a couple months ago I messed something up in my car by overrevving it. I changed the pushrods and had a compression check done, and it all turned out ok. Replaced a plug wire that was burnt and it ran good except for a slight stumble around 3000RPM. Then I took it to the track a couple weeks ago. After my second run, I noticed it was backfiring, not loud, but somewhat constant. So since the compression was good before, and the plugs were brand new, the wires all looked fine, I decided to pull the opti I replaced last summer and check the rotor. Here's some pics.
The rotor looks a little rusted over, does it always look like this?
Also pulled the coil wire and it looked kinda grimey
I guess if both these things check out, what else could be causing my backfire? Could one of the rockers have come loose? I have poly-locks and felt them all, none of them felt loose. Any help would be good for this n00b, thanks guys.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
