How would a Comp Cams XE230-236 work for my application.
I have a 97 Z with many bolt-ons, including a 150 shot of nitrous. I will be installing, ported and polished LT4 heads and intake, 1.6 RR, "R" lifters, 987 springs. I runs the nitrous maybe 2-3 per month and will probably make 3 trips to the track per year. The car is mostly a daily driver. Will the XE230-236 be a good streetable cam and have good response to the nitrous. Any info will be greatly appreciated.
Here are the spec on the cam:
I E
Adv Duration 282 288
Dur @ .050 230 236
Lift w/ 1.6 .544 .555
LSA 112
I E
Dur @ .050 230 236
LSA 112
The more i drive with this cam the less i notice i have it. I use to think it was almost unstreetable at times when the cam was new. I have been running stock gears, that will change this weekend though. I hope that adding 3.90's will take care of any cam surge i had, and help get it into the power range quicker. I can't answer the nitrous i don't run it and my cam is on a 112 so i don't think it would work to well.
Will the XE230-236 be a good streetable cam?
Overall, the cam feels more or less like stock until you get above about 3500 rpm, then it pulls like mad. In first gear (and a bit in second), the stock tach can't keep up, since it revs so fast.
BRAD
I like it....its very streetable with some tuning....remember youll be NA 99.9% of the time so NA should be your primary concern so I belive its a great choice. It has enough split to make the most of juce as well.
oldschool
Feb 9, 2016 09:21 PM
