How to wire up SS spoiler ???
Old Jun 7, 2004 | 09:23 AM
AZ2ENVY's Avatar
I just got the 98+ SS spoiler with the LED brake light
and I was wondering how do I hook it up ? I did a
search and found nothing . Thanks
Old Jun 7, 2004 | 09:38 AM
Mystic95Z's Avatar
Same as the stocker, except you will need to wire up a normal incandescent bulb in parallel before the spoiler to keep the ABS inop light from coming on.
-Tony
Old Jun 7, 2004 | 10:48 AM
AZ2ENVY's Avatar
Wont that melt a hole in the spoiler if I stuff it inside where
it cant be seen ?
Old Jun 7, 2004 | 11:26 AM
Some people use a relay. Tap into each of the two wires going to the spoiler. Run one wire to terminal 85 of the relay and the other to 86. That will provide the needed resistance so everthing will work right and the relay coil will dissipate heat without getting too hot. Use any standard automotive relay.
CARiD
May 6, 2015 07:49 AM
CARiD
Feb 9, 2015 09:35 AM
Alien
West South Central
Jan 11, 2015 12:51 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
