how to wire a mallory 667 s CD box to work with a 1997 firebird lt1
Old Aug 9, 2012 | 06:54 PM
mightymouse383's Avatar
I need help wiring my mallory 667s CD ignition box to my existing engine harness or whatever needs to be done to make it work. I see MSD sales a 8877 harness for 96 and 97 lt1's but it is for a 685 mallory and the 6 series msd boxes. Tried to do a search and all info I found is for a mallory 685, the instructions that came are kinda sketchy with no mention of a lt1. Thanks.
Old Aug 10, 2012 | 10:55 PM
Re: how to wire a mallory 667 s CD box to work with a 1997 firebird lt1
Anybody?
Old Aug 11, 2012 | 04:17 PM
Don'y know anything about it, but is appears that you have to use the box with:
Ignition Coils
The HYFIRE® VIIS Ignition System is designed to work with Mallory
PROMASTER® Coil Part No. 28880. Avoid using any other type of ignition coil.
Is that the coil you are using?
The harness you mention is to connect between an GM HEI distributor and a stock coil. So that would seem not to be intended to connect to the Mallory coil, that has screw terminals.
And the data sheet seems to show how to connect the 667s to the Mallory coil.
667S pdf, 667S description, 667S datasheets, 667S view ::: ALLDATASHEET :::
The mystery is whether the white wire from the PCM to the stock IC Module would serve as an input to the magnetic pickup connection on the 667s.
What are you trying to accomplish with such an expensive box? Looks like something that would support a 3-stage nitrous system rev limter and retard.
Old Aug 11, 2012 | 06:58 PM
I picked the box up from a friend for $100 bucks new in the box, I and going to be using it with my nitrous setup, I have a crane LX92 coil which is equivilent to the mallory 28880 according to Summit racing. I am going to use the retard function and the rev limiter and the 2 stage capibility.
After reading on the net last night, I think the white wire from the ICM is what would connect to the points terminal on the box, But I will wait so see if any one else has any more input. Thanks Fred.
lt1-xjs
Jan 17, 2015 07:52 PM
Jeff1904
Jan 3, 2015 12:00 AM
Injuneer
Dec 15, 2014 09:36 AM
blac94Z
Dec 7, 2014 08:40 AM
19redta96
Jul 23, 2002 12:25 PM
