How to "trick" the oil dummy light in the dash?
Old May 9, 2006 | 12:20 PM
Javier97Z28's Avatar
Moderator
My new Milodon pan doesn't have an oil level sensor provision.. no biggie I check my oil regularly given the nature of the car.
How do I trick the dash light aside from taking the bulb out? Can I drop a resistor of a certain value into the pigtail?
Old May 9, 2006 | 12:26 PM
Honda Hunter's Avatar
Re: How to "trick" the oil dummy light in the dash?
Couldnt the ressistance be measured from the sensor itself then duplicated with a resistor?
Old May 9, 2006 | 12:27 PM
Moderator
Yah, I guess I could just dip the thing in oil? I don't see a float of any kind on it, so it must work that way.
Old May 9, 2006 | 12:31 PM
bdc95ta's Avatar
cant u get it tuned out?
Old May 9, 2006 | 12:35 PM
Moderator
I think it's a "straight to the dash" sensor, doesn't go to the PCM. Kinda like the coolant temp sensor on the driver's side head is.
Old May 9, 2006 | 12:39 PM
Cant tune out the dummy lights (air bag, coolant, oil, asr etc.)
Old May 9, 2006 | 01:59 PM
GetaZforgetGT's Avatar
I think most people just cut the plug off and connect to two wires.
Old May 9, 2006 | 02:03 PM
makes sence.
Old May 9, 2006 | 02:10 PM
Moderator
So that means "oil full" is a reading of 0 resistance I take it?
Old May 9, 2006 | 02:13 PM
http://web.camaross.com/forums/showt...el+sensor+plug
Old May 9, 2006 | 02:20 PM
Moderator
Looks that way then! Thanks Jeff.
Old May 9, 2006 | 04:57 PM
Z95m6's Avatar
What i did was i just took a resistor i had laying around and stuck it in the plug. It worked, it was one of the ones i had laying around from trying to desensitize my knock sensor from years ago.
Old May 9, 2006 | 10:11 PM
cehan's Avatar
The "sensor" is not really a sensor, it's an on-off switch. Shorting the wires together will cause the light to stay off, just like Shoebox said in the other thread.
Magenta_Hearts
Mar 29, 2017 08:54 PM
jj71787
Jan 31, 2015 10:20 PM
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
