How are these flow numbers?
Old Mar 26, 2004 | 08:02 PM
NONO5.0's Avatar
These are the flow numbers on my LT1 heads off a '95 T/A. How do they look? Are they bad, good, average, above average or great? I don't know anything about flow numbers so I'm kinda lost
2.00/1.56 Manley race flow valves
Crower Springs, Chromemoly locks and retainers Good to .580 lift
Comp Cams screw in studs and guide plates
Flow as follows:
No Port attachments
.100 71/62
.200 133/112
.300 187/157
.400 219/185
.500 248/192
.550 258.5/193.5
Thanks guys!
Old Mar 27, 2004 | 06:56 AM
FASTFATBOY's Avatar
Are these my old heads? I sold them to a guy in Saraland with a white T/A.....do they have Killians Porting stamped in the end of the head?
David
Old Mar 27, 2004 | 08:00 AM
IllusionalTA's Avatar
they look really good put a joe o cam in and make some power....
Old Mar 27, 2004 | 08:33 AM
97Z-M6's Avatar
i heard he is not grinding cams anymore. is this true.
Old Mar 27, 2004 | 10:28 AM
FASTFATBOY's Avatar
As stated above , I had a set with identical numbers. Put a custom grind Crower cam in 224/228@.050 112 LSA shorty headers 52 Mm throttlebody, 30 lb SVo injectors in a 3700lb stock suspension 94 six speed Z on drag radials went 90 MPH in the 1/8 mile. These heads will make good power with the right cam.
David
Old Mar 27, 2004 | 11:23 AM
Mikey 97Z M6's Avatar
Numbers look pretty good actually. I'd rate them somewhere between a stage I port and a full stage II.
Mike
Old Mar 27, 2004 | 12:06 PM
FASTFATBOY's Avatar
Mike
I see your best pass was a 12.39@114, what was the 1/8 mile time and speed on that pass? I never ran mine 1/4 mile with that particular combination.
David
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
