How to tell wat size these are?
Re: How to tell wat size these are?
If the diameter top and bottom is the same they are 7/16" if the tops are a smaller diameter they are 3/8. The part that screws into the head is 7/16 but stock studs and stock replacements neck down to 3/8", when we upgrade it is just that tophalf that is larger and is then the same diameter as the bottom.
Originally Posted by 94_camm
I got new trickflow rocker arm studs from a friend....how do i tell watsize they are?
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
