How to tell pcm what # injectors you’re running with Tunercat?
Old May 16, 2025 | 12:35 AM
SweetToothMcRib's Avatar
I’ve got a 1994 z28 and I just got done with my engine rebuild and started the car for the first time, (fired right up and ran great!) I’ve got 42# injectors which is a fairly big jump from the stock 24s. I only ran it for a short bit just to see if it’d start. Now I’m looking through the tuner at software and can’t find how to tell the PCM that I’m running a bigger injector. Anyone know how?
Old May 16, 2025 | 06:03 AM
Johnny Bill's Avatar
Re: How to tell pcm what # injectors you’re running with Tunercat?
I’m new to Tuner Cats but I believe it’s in the ECM constant table.
Old May 16, 2025 | 06:57 AM
Got it, thanks!
Old May 16, 2025 | 09:39 AM
You have to program both injector flow rate and offsets. Flow rate has to be adjusted for the pressure at which the injector flow was rated, if not 3 bar (43.5 PSI). Ford injectors for example are flow rated at 2.7 bar (39.15 PSI). If running something other than the LT1’s standard 43.5 PSI, you have to take that into consideration as well. You manipulate that on a calculator to obtain the flow rating based on square root of the pressure ratio.
Have you seen this guide:
https://www.lt1pcmtuning.com/tips/
Old Dec 3, 2025 | 08:02 PM
Originally Posted by hikoma@hostme.m
You need to enter the new injector size in your tuner’s fuel setup. Look for the field labeled “Injector Size” or “Injector Flow” and set it to 42 lb/hr (about 433 cc/min). Make sure any injector delay or battery voltage correction settings are correct, then reflash the PCM so it knows you’re running the larger injectors.
Please respond to my request in your earlier post:
https://www.camaroz28.com/forums/new...repair-890300/
OVA1
Apr 29, 2009 10:03 AM
tamatt27
Feb 24, 2005 09:47 AM
stew's94z
Sep 6, 2004 07:06 PM
JeffK95Z
Oct 15, 2003 09:22 PM
Bryan 94 Z28
Apr 13, 2003 11:21 AM
