How to tell if rod is bent?
A car I'm working on had a lot of antifreeze build up in #1 cylinder when it blew the head gasket. I tried starting it a few times before I knew what happened, and I want to know if there's a way to check internal damage to the rod/piston without pulling the whole motor.
It seemed to turn over fine when I was trying to start it.
You could pull a head and see if it (victim piston/rod) comes up as high as the others on that side. If its the same its probably ok. If its lower, then its bent. You could also check this with a piston stop tool - the kind that threads into the spark plug hole.
it could be very hard to do this way...and bent rod isnt a ton shorter then a normal one...compression test is best way... or pull motor apart
Next to no real way short of disassembly and checking with the appropriate tools. A compression test is not reliable unless the bend is fairly severe; a 'tweaked' rod can still fall into the acceptable range of deviation.
CARiD
Sep 30, 2015 05:44 AM
