How to tell if rod is bent?
Old Mar 13, 2009 | 12:55 PM
12sec97Z28's Avatar
A car I'm working on had a lot of antifreeze build up in #1 cylinder when it blew the head gasket. I tried starting it a few times before I knew what happened, and I want to know if there's a way to check internal damage to the rod/piston without pulling the whole motor.
It seemed to turn over fine when I was trying to start it.
Old Mar 13, 2009 | 02:10 PM
powerslide350's Avatar
Compression test. I doubt you bent a rod from having the sarter crank it over. If a cyl was full of water it would have just stoped cranking.
Old Mar 13, 2009 | 06:27 PM
Air-Adam's Avatar
You could pull a head and see if it (victim piston/rod) comes up as high as the others on that side. If its the same its probably ok. If its lower, then its bent. You could also check this with a piston stop tool - the kind that threads into the spark plug hole.
Old Mar 13, 2009 | 07:26 PM
Daniel6718's Avatar
it could be very hard to do this way...and bent rod isnt a ton shorter then a normal one...compression test is best way... or pull motor apart
Old Mar 16, 2009 | 05:09 PM
The_Bishop's Avatar
Next to no real way short of disassembly and checking with the appropriate tools. A compression test is not reliable unless the bend is fairly severe; a 'tweaked' rod can still fall into the acceptable range of deviation.
Old Mar 16, 2009 | 07:01 PM
Air-Adam's Avatar
Ya, its definitely not the best way to do it. Its an option though.
Old Mar 25, 2009 | 01:45 PM
marshall93z's Avatar
Unless it starts right up, like mine did. Bent the hell out of it!
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
