How to tell if a pushrod is hardened on an online catalog?
Old Feb 29, 2008 | 12:02 AM
Ironxcross's Avatar
Where does it say it? I can't tell the difference.
http://www.compperformancegroupstore...y_Code=PSHRDHE
http://www.jegs.com/p/Comp+Cams/752433/10002/-1/10225
help
Old Feb 29, 2008 | 12:31 AM
JooneJune's Avatar
4130 chromemoly material
Found in CompCams hi-tech rods. You can use any brand just look for the chromemoly one piece rods. range anywhere from 80-140 bucks. OEM length is 7.2 if im not mistaken...
Old Feb 29, 2008 | 02:02 PM
guest74777's Avatar
Guest
comp magnum and comp HI-techs are hardened, also trickflow has a hardened rod. I had to go with the hi-techs because the magnums do not come in 7.100 length and the hi-techs are kinda pricey.
Old Feb 29, 2008 | 02:06 PM
dangalla's Avatar
i went with the trick flow due to them being much cheaper
Old Feb 29, 2008 | 02:07 PM
guest74777's Avatar
Guest
yea I would of but the performance shop by my house had to order them so I just went with the hi-techs so I could start the car.
Old Feb 29, 2008 | 03:00 PM
'94 Bad A Z28's Avatar
The ones you posted are all 3-piece, they might be hardened but you are better off going with a 1-piece pushrod.
marlar98
Sep 12, 2018 07:18 AM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
damnyankee36
Sep 9, 2015 07:06 PM
