How to take apart the opti
Old Oct 18, 2007 | 12:14 PM
southern78's Avatar
What size or type of screw/bolt is that that holds the opti together? I was wanting to take my old apart to check it out. Maybe a torq screw or something?
Howard
Old Oct 18, 2007 | 01:33 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I believe it's an E4 torx.
Old Oct 18, 2007 | 05:08 PM
windsma's Avatar
what are things to look for in the inspection?
Old Oct 18, 2007 | 05:36 PM
-loose rotor/missing screws
-damaged rotor/shattered
-burned contacts on the cap, and on the tip of the rotor
-missing rotor button on the cap
-moisture buildup
-rust
-carbon tracking
-rust buildup in the optical sensor, blinding it
-damaged or corroded connector pins
-corrosion in the plug wires and coil wire terminals
-cracks in cap
-loose or corroded bearing/hard to turn
Old Oct 18, 2007 | 06:02 PM
BTC's Avatar
BTC
I don't have an opti here in front of me, but after getting the cap off my original opti, using the aforementioned torx socket, I couldn't get the rest of it apart to see what it looked on the side where the optical sensor is located. What's needed to fully disassemble the opti? It seems like there were some really small screws that had to be removed, but it's been a few months and I don't clearly recall. I do remember that I didn't seem to have anything small enough for the job.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
