how to set timing on CARBED LT1
Old Feb 23, 2005 | 10:52 AM
TerroRx7's Avatar
hello
I am doing a carbed LT1 conversion on my 1985 RX7
and I will use the stock LT1 alternator ( no AC no PS ) + HEI distributor
my questions are
1st choice: if I use stock crank hub and balancer
how can I set the timing ?
I am asking because the LT1s don't have timing marks
2nd choice: sbc style damper and pointer
can I use SBC damper on stock LT1 crank ?
which type should I use "Internal" or "Internal/External" damper ?
any input appreciated
thanks
Old Feb 23, 2005 | 01:33 PM
1stz28's Avatar
Re: how to set timing on CARBED LT1
Very crude way...find TDC while assembling engine or other means and mark balancer and point to 0. Determine circumference of balancer, divide by 360 and that is one degree. Start measuring and marking. I'm sure someone will have a more precise and proven method.
Old Feb 23, 2005 | 03:56 PM
SStrokerAce's Avatar
Originally Posted by TerroRx7
hello
my questions are
thanks
Get a LT1 balancer with timing marks on it. Powerbond, ATI, Fluidampir all have them.
There is a Opti Plug that GM sells with a pointer on it, or you can modify the cover and a billet timing pointer and set it up that way.
Bret
Old Feb 24, 2005 | 10:25 AM
TerroRx7's Avatar
1stz28
I like your idea ( Cheap a$$ )
SStrokerAce
I will use billet pointer with stock marked damper
thanks
Old Feb 24, 2005 | 02:27 PM
1stz28's Avatar
1stz28
SStrokerAce
thanks
Thanks...it is definitely cheap but I bet it would work. Don't know why it wouldn't. I will admit however that SStrokerAce's idea would be much cleaner looking, and probably more accurate. I kinda figured there was aftermarket parts available to do it but I am still kinda new to these cars and still learning.
Old Feb 24, 2005 | 04:22 PM
SStrokerAce
thanks
Sent you a pic of what I was talking about.
Bret
Old Feb 24, 2005 | 05:55 PM
NOMAD's Avatar
I timed heathers car by ear when we did her carbed LT-1 swap into her third gen. Of course, i've been doing this for years, so I really wouldn't suggest it...lol
-Shannon
Old Feb 24, 2005 | 06:09 PM
-Shannon
I can't ever suggest that.... I've seen motors that were off 1 deg on timing be down 20hp easy, and what looks or sounds right is off 45hp on the dyno.
Bret
parkers Z28
Mar 11, 2016 08:14 PM
siguy
Nov 27, 2014 10:07 AM
draven666
Nov 26, 2014 07:16 PM
draven666
Nov 26, 2014 07:10 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
