how to set timing on CARBED LT1
hello
I am doing a carbed LT1 conversion on my 1985 RX7
and I will use the stock LT1 alternator ( no AC no PS ) + HEI distributor
my questions are
1st choice: if I use stock crank hub and balancer
how can I set the timing ?
I am asking because the LT1s don't have timing marks
2nd choice: sbc style damper and pointer
can I use SBC damper on stock LT1 crank ?
which type should I use "Internal" or "Internal/External" damper ?
any input appreciated
thanks
my questions are
thanks
Re: how to set timing on CARBED LT1
Very crude way...find TDC while assembling engine or other means and mark balancer and point to 0. Determine circumference of balancer, divide by 360 and that is one degree. Start measuring and marking. I'm sure someone will have a more precise and proven method.
Originally Posted by TerroRx7
hello
my questions are
thanks
my questions are
thanks
There is a Opti Plug that GM sells with a pointer on it, or you can modify the cover and a billet timing pointer and set it up that way.
Bret
1stz28
I like your idea ( Cheap a$$
SStrokerAce
I will use billet pointer with stock marked damper
thanks
)SStrokerAce
thanks
I timed heathers car by ear when we did her carbed LT-1 swap into her third gen. Of course, i've been doing this for years, so I really wouldn't suggest it...lol
-Shannon
-Shannon
-Shannon
-Shannon
Bret
