how to: roller rocker 1.6 and springs
Old Feb 26, 2009 | 05:42 AM
ussj4brolli's Avatar
ok...i see all kindsof people saying people should have these installed.
i want to do these...what benefits do they have over stock?
how long does it take for a n00b-mediam exp? iv done alot of outside engine work, never inside..
could someone post or link to some sort of step by step guide? and maybe a link to the correct parts?
1994 z28 lt1 performabuilt level 2 4l60e
thank you everyone!
Old Feb 27, 2009 | 05:21 AM
Basic questions about mods to the LT1 engine should be posted in "LT1 Based Engine Tech". That's not what "Advanced Tech" is for. I'll move your post to the correct forum for you.......
Old Feb 27, 2009 | 06:46 AM
My Tech Page has a "how to" for changing the valve springs (which you will want to do when going to 1.6 rockers) and many other things. HP estimates probably in the range 10 or more on a stock engine. The rockers are easy-just a matter of swapping them out and adjusting them. The springs take a little time, but once you get one done, you should have them all in a couple of hours or less. Total time will be based on experience.
Old Feb 27, 2009 | 02:59 PM
deerslayinrenek's Avatar
Use his website^^^^^ Thats what I used to change mine as well as other things......you can do it, just research it first and use common sense and you will be fine........good luck
Old Feb 27, 2009 | 11:46 PM
mrmint69's Avatar
I decided to pay the $200 and have the Chevy dealership do the springs and rockers. First time I have had more money than time. Just know if I do it myself it will take all weekend.
Old Feb 28, 2009 | 10:29 AM
95zsean's Avatar
Use shobox's web site!!!!!! It's got all you will need to do this swap and ALOT MORE!!!! Make a donation if you find it usefull... I'm sure you will!!!!
Good luck
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
