How to replace o2 sensors?
Old Apr 10, 2003 | 10:58 AM
Zio's Avatar
Zio
Hey guys i need new o2 sensors. Do I have to take the olds ones out, cut the wires, then solder the wires back togther? BTW it is on aa 95 formula.
thanks
Tom
Old Apr 10, 2003 | 11:00 AM
Javier97Z28's Avatar
Moderator
Your O2 sensors on your 95 are located right below your exhaust manifolds. A little tough to get to but you'll need to just get at them with a wrench and remove them. They have a connector so no need to cut anything.. just unplug and replace them
Old Apr 10, 2003 | 11:16 AM
Zio's Avatar
Zio
Thanks for the help. The driver side doesn't look bad to get to. I have shortie headers that we on the car when i go it, so they might give better access. I must have been thinking about o2 extentions that you have to solder together.
thanks for the quick reply
thanks
Tom
Old Apr 10, 2003 | 11:24 AM
I had to use an O2 socket on the RH one. I did not have enough room to swing a wrench.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Fatdog2
Feb 13, 2015 08:19 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
