How to remove T56 bellhousing?
Old Aug 16, 2004 | 07:21 PM
Serene's Avatar
How did you get the bolt on the bellhousing that is on the top of the drivers side? Not the very top one, the one on the top of the side of the bellhousing.
It is right next to the body, i cant get a socket over it!
Thanks!
Old Aug 16, 2004 | 07:23 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: How to remove T56 bellhousing?
use a short socket with a wobble extension, or a universal joint socket.
Some cars are tougher than other. if that doesnt work, you can pry the motor over a little and/or dimple the tunnel right there
Old Aug 16, 2004 | 07:44 PM
Serene's Avatar
I can get a 12 pt wrench on the bolt, but its too close to the bellhousing and i cant turn it. Ill probably have to dent the body.
Old Aug 16, 2004 | 07:53 PM
neversummer's Avatar
This is not for the faint of heart. BUT....
I finally cut a flap in body from the inside. It was the best decision I ever made. You have to cut the carpet and padding, pull them back, then cut the body, fold it back, and there is your bolt!
Old Aug 16, 2004 | 08:41 PM
Serene's Avatar
I finally got the damn thing out. I got the 12pt on the thing half way and loosened it up, then used my index and middle finger to turn it until it came out. Took FOREVER.
KYWes
Jun 14, 2022 06:52 AM
birdblack
Jul 8, 2015 07:23 AM
BigWil
Mar 29, 2015 12:24 PM
Duke
Jul 31, 2002 05:13 PM
