How to re-adjust rockers after initial
Old Mar 31, 2009 | 08:32 AM
  #16
87bandit's Avatar
that while running vid looks like pure chaos, coolant is spewing everywhere, oil is spraying all over the exhaust lol
I've always been a fan of doing it while the car is off, never had a problem. I don't trust my ears enough personally to do the while-running-method
Old Mar 31, 2009 | 01:55 PM
  #17
mrmint69's Avatar
I always leave the radiator cap on when adjusting mine and use card board to keep oil off the exhaust. I also do one at a time.
Old Feb 3, 2010 | 07:07 AM
  #18
blufc3s's Avatar
Originally Posted by Kevin Blown 95 TA
Don't forget to turn the polylock an additional 1/8 turn after tightening the set screw to really cinch them down.
Isn't this having the same effect as tightening the screw more? I suspect you're getting more leverage with the box end wrench on the nut than the allen wrench on the screw.
Would it be more accurate/consistent to use a 3/16" allen socket & tighten all the screws to a given torque? I read on some site a guy used 30 LBs. which seems a little excessive to me. I'm thinking of doing mine at 20 Lbs.
I'm doing mine tomorrow so any feedback on this method would be appreciated.
Old Feb 3, 2010 | 07:19 AM
  #19
Yes, it would increase the lash. Just hold the nut and cinch down the allen bolt. It's not rocket science. People go to all these extremes where none are really necessary.
Old Feb 3, 2010 | 09:27 AM
  #20
pizzi-man's Avatar
You will get a ticking from a exhaust leak at the head and usually happens from the underside of the exhaust manifold or headers where it can't be seen. Many people have mistaken a exhaust leak for a loose rocker and chased their tail readjusting rockers
Old Feb 3, 2010 | 10:41 AM
  #21
Z28SORR's Avatar
Interseting technique used in the video. The proper tool helps: http://www.google.com/products/catal...195&sa=title#p
Old Feb 5, 2010 | 10:58 AM
  #22
JAKEJR's Avatar
They tried to turn them too far. Some people don't have a feel for how tight is enough until they break things. Those are opposite of the ones whose rocker arms are always coming loose - and I've seen a lot of posts about that, not breaking ploy locks.
I agree. I ALWAYS do it that way too, even on solid rollers running a stud girdle.
There have been a couple of recent posts of the poly locks lossening. In response to OPs problem members have recommended turning the lock about 1/16" after the set screw is tightened. As I've posted before, I don't know of any torque setting for that, it's just done by feel.
CompCams and I recommend loosening the poly lock and waiting a short period of time to allow the lifter preload to relax so the pushrod cup can return to the top.
Jake
Old Feb 5, 2010 | 07:54 PM
  #23
GREGG 97Z's Avatar
I used the method listed on Shoebox's site to adjust mine. I didnt have any success adjusting them with it running. Engine off method is much easier I thought.
Old Feb 5, 2010 | 08:17 PM
  #24
wrd1972's Avatar
Dont overtighten the polylock. I used to torque the set screws to 35# and one day last year, a single polylock broke in falf. It caused no damage, just some clicking from a loose rocker. Luckily i had a spare in the toolbox.
Now I torque the set screws to 25#.
Old Feb 6, 2010 | 12:03 PM
  #25
JAKEJR's Avatar
Interestingly, the preload or valve lash isn't effected at all in doing the additional tightening procedure.
Actually all that's being done is additional tightening of the OD threads of the set screw with the ID threads of the larger poly while, at the same time, applying a tad more pressure to the top of the stud. This is what prevents future loosening by locking all three together better.
How much to tighten is a "feel thing" (muscle memory) that engine builders develop over the years. I wish I had a torque spec to share, but I don't. Simplest to say, as soon as the wrench moves, that's enough.
Like so many other things, there are different ways to accomplish the same thing. It's just how I've done it on both street and race engines since Hector was a Pup.
Jake
Old Feb 17, 2010 | 10:58 PM
  #26
marshall93z's Avatar
Just to update this thread from the dead, I'll quote myself!
Originally Posted by marshall93z
Never touched mine after I built my engine. Have 10-12k miles on it now and no issues yet.
25,000+ miles on it now and have had NO problems with rocker coming loose.
Old Mar 7, 2010 | 08:17 AM
  #27
blufc3s's Avatar
Do all roller rockers make a light ticking, even when adjusted properly?
Mine sound like solid lifters, maybe a little quieter.
I noticed some play in the rollers on the tip of my NIB Scorpion rockers, which I think all R/R's have, maybe for heat expansion.
Thanks for any input.
Stew
Old Mar 7, 2010 | 09:43 AM
  #28
95z28onjuice's Avatar
I ajust mine with the car running. its the best way to make sure it is all perfect and there is no noise from a rocker. othere than that if its not running then just make sure your a tdc #1 and #6 and go over all of them again dont be lazy or you will ust have to do it again
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
