How To Pull Powersteering Pulley
Old Nov 9, 2005 | 01:27 PM
93 4mula's Avatar
How do you get this dang thing off? I bought puller but it isn't working
Old Nov 9, 2005 | 03:33 PM
30696bird's Avatar
Re: How To Pull Powersteering Pulley
It's pressed on so it's gonna be a pain! Let me try to explain how I did mine.
I took the whole pump and put it in a freezer baggie of ice (making sure the shaft got iced EXTREMLY good). Leave the pump in ice for ATLEAST 30 minutes. When you take the pump out get a little propane torch and heat the pulley (try not to heat the shaft to much, but get close to the center of the pulley where it meets the shaft). After a little heat from the torch you "should" be able to put the pulley on 2 boards or something to hold the pump off the ground so you can tap the pulley off the shaft. Use a little common sense and tap the shaft while it's proped up by the pulley and it should slide right off.
It worked like a charm for me. Cold shrinks.........heat expands, all about the physics. Or you could take it somewhere and have it pulled off for a little $$, which ever you choose.
BLK1997Z28
May 7, 2015 03:01 PM
cyteone
Feb 7, 2015 06:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
