How to pull crankshaft hub?
Old Jun 24, 2003 | 06:29 PM
97Camaro007's Avatar
I am about to do another cam change this weekend and I was wondering how ya'll get the hub off....everytime that I have done it before I have went to GM and got there special puller.....but I want to do this on Sunday and they are not open on sunday....I know someone out there has a trick to pull this thing....
Michael
Old Jun 24, 2003 | 06:56 PM
95_RipperZ's Avatar
Go to Auto Zone and get their 3 toe puller. It uses 3 bolts you put through the holes on the hub. You will need t ofid soe nuts to put on the back on the bolts though. Luckily i had them at my house. Then put something in the crank hub bolt hole that wont ruin the treads. I used a 1/4" extension. Then if you are an auto, use a pry bar and wedge it between the bolts and under the alternator bracket to keep the crankfrom moving. Should come right off then.
Old Jun 25, 2003 | 02:21 AM
94 TA TT2S's Avatar
As stated above ...I did the exact same thing ....it takes a few turns to get it going but it will go once you get it to that point....
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
